Old 08-27-2008, 05:25 AM
musclecar fan musclecar fan is offline
Default Diverter Valve Rebuild Source Needed,... I Think?
I have a 69 SS 350 and need my smog diverter valve rebuilt, I think. On de-acceleration or between shifts I get backfire noises out of my exhaust. I never had this before, but since re-installing my A.I.R. smog equipment now I do. Any thoughts on what is causing this? maybe the gasket between the diveter valve and the tube where it attaches is bad....? Help..... Thanks
Old 08-27-2008, 05:57 AM
Default Re: Diverter Valve Rebuild Source Needed,... I Think?
Bill Hoedel has an exclusive arrangement with Don D. (ex from ASL)..... FYI
I myself would like to what the alternative is, at what quality and what price.
Pretty sure Don D is only rebuilder to ever R&R Yellow Zinc cover, and replate !!!!!!!
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 08-27-2008, 05:58 AM
On a working smog set up...I think that this is normal (which is one of the reasons why everyone took them off... )
I could be wrong though...
Old 08-27-2008, 06:00 AM
What you are hearing is the smog system doing it's job. It is injecting air and allowing combustion of the unburnt fuel in the exhaust.
Old 08-27-2008, 06:12 AM
Be proud that you are doing your little part in preserving our environment!
Old 08-27-2008, 06:23 AM
MosportGreen66's Avatar
If the system does need rebuild, I unconditionally recommend Bill Hodel!
Old 08-27-2008, 06:50 AM
Thanks Charley!
Old 08-27-2008, 07:02 AM
How loud & routine is it?
You really shouldn't hear enough to be that noticeable all the time.
It could be the pressure relief valve inside the diverter sticking open,or not at all.Do you have manifold,(not ported),vacuum running into the Diverter valve itself?
Does the Smog system you put back on it have a working pump w/guts,or is it a dummy pump w/operating diverter valve?
Just for kicks,check your dwell & ignition timing with a timing light too.
Old 08-27-2008, 08:50 AM
The system is stock with full functioning smog pump with the guts intact. I routed the 1/4 inch hose from the back of the diverter valve to the side nipple on the side of the quadrajet carb on the passenger side. The kit also came with a white "T" but I didn't know where that went. There is also a 1/4 hose that runs from the back of the intake to the distributor vacuum advance. Should I "T" off of that?
As to when it makes the back-fire/ popping noises, my car is a 4sp and when I wind out first and shift to second I hear the noise. Also if I'm going down a steep hill and coast in gear at speed down the hill I hear it as well.
Old 08-27-2008, 09:34 AM
JIM's Avatar
JIM JIM is offline
I have been doing the rstoration of these valves for years in the correct cynadide cadiumn not the cheap alkalide cadiumn that everybody else uses!!!!!
Jim
