Old 12-18-2008, 02:39 AM
Default You won't see this every day....
EXTREMELY RARE SNOW EVENT ACROSS THE DESERT SOUTHWEST...
AN UNUSUAL COMBINATION OF SUBTROPICAL MOISTURE AND COLD... NORTHERLY... LOW LEVEL AIR HAS PRODUCED A RARE SNOWSTORM ACROSS THE LOWER ELEVATIONS OF THE MOHAVE DESERT... INCLUDING THE LAS VEGAS VALLEY. THIS SNOWSTORM WILL PRODUCE SIGNIFICANT IMPACTS TO THE LAS VEGAS VALLEY AS 3 TO 6 INCHES OF SNOW ARE LIKELY AT MOST LOCATIONS INCLUDING THE LAS VEGAS STRIP. HIGHER AMOUNTS ARE POSSIBLE... PARTICULARLY ACROSS THE WESTERN PORTIONS OF THE VALLEY WHERE TOTAL ACCUMULATIONS OF UP TO 10 INCHES ARE FORECAST.
THE SNOW BEGAN TO FALL ACROSS MUCH OF THE LAS VEGAS VALLEY EARLY WEDNESDAY AFTERNOON AND WILL CONTINUE THROUGHOUT THE OVERNIGHT HOURS. THIS WILL LIKELY BE THE BIGGEST SNOWSTORM TO IMPACT LAS VEGAS SINCE 1979... WHEN 7.8 INCHES OF SNOW WAS MEASURED AT MCCARRAN INTERNATIONAL AIRPORT.
SNOW REMOVAL EQUIPMENT IS EXTREMELY LIMITED IN THE LAS VEGAS VALLEY AND THE EFFECTS FROM THIS STORM WILL LIKELY LINGER INTO THURSDAY. TEMPERATURES QUICKLY REBOUND IN MANY INSTANCES FOLLOWING SNOW IN THE LOWER DESERTS. THIS WILL NOT BE THE CASE ON THURSDAY... AS THE TEMPERATURE WILL NOT CLIMB OUT OF THE 30S.
ELSEWHERE ACROSS THE LOWER DESERTS... ABOVE 2000 FEET... SNOWFALL OF 6 TO 18 INCHES IS EXPECTED. FOR ADDITIONAL DETAILS PLEASE SEE THE LATEST WINTER STORM WARNING
