Old 02-21-2010, 11:17 PM
69 Post Sedan's Avatar
Default GM Richmond 4.56 12 Bolt Gears 3 Series
THIS IS A REALLY NICE SET OF RICHOND 4.56 RING AND PINION GEARS FOR A GM 12 BOLT WITH A 3 SEARIES CARRIER. THEY ARE IN LIKE NEW CONDITION. HERE ARE THE SPECS:
Ring and Pinion Ratio 4.56:1
Cover Bolts 12
Ring Gear Bolts 12
Pinion Spline Count 30
Carrier Series 3
Ring Gear Rotation Standard
Ring Gear Teeth 41
Pinion Gear Teeth 9
Ring Gear Diameter (in) 8.875 in.
Pinion Shaft Diameter (in) 1.625 in.
3.07:1- 3.73:1 CARRIER
Here is a link to summit for more info.
http://www.summitracing.com/parts/RMG-6903061/
$125.00
608-751-7303
Thanks SYC
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
