HI there is a post that talked about oiling probems on the ZL1 can some find this post for me THANKS
Barry Allan |
The L-88 and ZL-1 engines had a fantastic lubrication system that to this day is one of the best ever designed and there is actually very little that can done to improve it. Stick with the GM factory matched parts with some Mobil One synthetic oil and that's about as good as it gets. If there's any problem, it's usually because someone didn't follow the GM Power Parts specifications and thought they could improve something that can't be improved upon!
1962 Biscayne O-21669 MKIV/M-22 1962 Bel Air Sport Coupe 409/1,000 |
It dealt with making sure you have the intake valley plugs in place. There are 3 1/8" pipe plugs that must be installed there. Also the oil filter check valve must be in place as well.
1968 Z/28 34,000 mile, born with engine and trans, Shipper, California car, Fathom Blue, deluxe interior, M21, 3.55 Posi 1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 Anti-Spin differential, California car, PS, PB, PW, AC, Jetfire 2 option package. |
This was a thread Albert posted about the oil pres issues. Turned out to be a simple fix, with plugging lifter valley holes, as stated above.
https://www.yenko.net/ubbthreads/show...0/fpart/1/vc/1 |
HI THANKS GUYS
Barry Allan |
