Old 04-13-2010, 05:32 AM
bad1racing bad1racing is offline
Default M20,M21,or M22?
I'm gonna be looking for a new trans for the Nova.The old one is toast,broken ear on the case,used up gears and syncros.More to rebuild it right than to buy new with the good stuff in it.The trans that was in it I beleave is a M20 with 2 rings on the input.Wouldn't mind a M22 with a supercase.That would do everything that I could throw at it. Any advise is appreciated.
Thanks in advance.
Kendall
70 Nova SS ZZ427 TKO600 5speed 3.55Posi
Old 04-13-2010, 05:43 AM
x  Baldwin  Motion's Avatar
Default Re: M20,M21,or M22?
If I had it to do over, it would be an M22 in the new case with the Italian gears. Let's see who can get the website first. I heard they had new ones for 1800. If numbers matching doesn't matter...
Complete new Muncie M22 1775.00 No core charge
http://www.tbtrans.com/muncie_4_speed.htm#new_unit
All of our Muncie units are built with the new muncie supercase,
super tailhousing, and the masiero italian gearsets, we also use the
new iron center midplate,along with the roller bearing sidecover
making this unit the toughest thing on the street!!!!!!!
Old 04-13-2010, 05:54 AM
I'm tossing this idea around too. I have the original M-20 trans in my 69 ElCamino, but if I were ordering the car new, I would have ordered the M-22.
I think I'll put the numbers matching trans on a shelf and stick a new M-22 behind the L-78. Gonna have to get a new clutch disc, and input shaft, but thats no big deal. Everything else, like the shifter, pressure plate, mount, etc can be reused.
69 El Camino
69 Nova
C7 Vette
Old 04-13-2010, 05:56 AM
Chris,Thats the one I was thinking of,but wanted some more input.Gonna pull the trigger within a month so doing some shopping.
Kendall
Old 04-13-2010, 06:05 AM
Like Bill says, putting my original trans on the shelf would have been smarter 5 or 6 years ago. Now, just finished the second major repair/rebuild and I've been advised to "take it easy". That's going to be difficult with a new LT1
Old 04-13-2010, 06:11 AM
markjohnson's Avatar
markjohnson markjohnson is online now
I purchased an M-22 Supercase Muncie a couple of years ago for my current Biscayne. The main reason I went with it is because of all the cars I've owned in my life, I've never had one with a real Rockcrusher in it. That was a missing part of my life that needed fulfillment! Now.......I don't know how hard you have your heart set on a new Muncie, but I do know that the next transmission that I buy will be a Tremec TKO 600. It's got the lower First gear AND an Overdrive in Fifth. You can put a stock style shifter on them, they are very reasonably priced, and nobody but you knows that it's in there! I've just heard too many good things about those Tremecs and everybody seems to often say that it was the single best modification that they've ever done to their car. Not trying to talk you out of the Munice, just some food for thought.
Old 04-13-2010, 07:01 AM
69 Post Sedan's Avatar
If you have to have a Muncie, go with a set of M22W Italian gears.
With the right set of rear gears it's better on the street/highway but you still get the strength of a M22.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-13-2010, 07:16 AM
ORIGLS6 ORIGLS6 is offline
Call Crash.
Old 04-13-2010, 04:51 PM
What state is this company located in???
Thanks
Peter
Old 04-13-2010, 05:23 PM
[/ QUOTE ] I agree! The M22's even with the new gears and so forth are really not that strong. Besides I don't think the new Italian gear M22's whine like the old days. Tremec, used Jerico etc.
