Old 10-07-2011, 04:29 AM
Smokey Smokey is offline
Default Enclosed Trailers....
Over the years I been getting bigger and bigger and bigger trailers. Started out with a Haulmark which was ok because I didn't know any better.
5 years ago I was short on space and picked up a 32 foot Team Spirit because of its size and it was twice as pretty and the same quality of a std Haulmark.
Since getting that I stepped up and go a decent diesel to pull it and was wondering about a Featherlite. I know some people here on the have them and was wondering since its all alumn and nicer yet on the quality level, do they get better mileage?? Or will I be stuck at going 59 mph if I want to get 15-17mpg??
Old 10-07-2011, 01:59 PM
njsteve njsteve is offline
Default Re: Enclosed Trailers....
15 hauling? I can only dream of that with my 95 6.5 diesel K2500 Suburban and 24 foot Pace trailer. I get more like 9 mpg towing. What are you pulling with?
Old 10-07-2011, 02:53 PM
Alss's Avatar
Alss Alss is offline
my 07 Duramax get almost 12 running 60-65..anything over that down to 10.5..pulling a 26 ft Pace, and thats alsmost the same running with the trailer empty. I looked into the featherlites..and went with Pace...the savings in price bought alot of fuel!
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 10-07-2011, 04:43 PM
kwhizz kwhizz is offline
Duramax Diesels are the best general purpose vehicles ever developed for towing.......IMHO.....
Old 10-07-2011, 05:08 PM
PxTx's Avatar
PxTx PxTx is offline
I've never owned a diesel. When comparing my 2001 Chevy w/ 8100 gas to a co-worker's 2006 Duramax I beleive the gas truck is much less expensive to own. My purchase price was significantly lower too. Talking stock for stock here and I admit that there are some diesel mods which really bring on the power.
I don't seem to see much difference in pulling my 28' enclosed loaded or empty. I would suspect at best that would be a fair comparison to the difference in a FL trailer. I get 13 mpg in my truck and 9-10 mpg pulling the trailer empty or loaded.
For the purpose of talking about economy and the cost to go X amount of miles, it seems diesel fuel is generally more expensive- pretty much making the few extra mpg towing a wash. It also seems like diesel loose mpg in the cold much more than my gas which is pretty consistant.
I also like the fact that I am not searching for diesel fuel when I'm out and about in PA. Now when it comes time to replace my truck, I'm not sure what options I'll have since the 8100 is NLA. I'll probaby end up with a Duramax, but I'm loving my gas truck for now.
Sorry for the rant, I think I did kinda throw my thoughts on the difference in mpg from the weight savings on the FL trailer vs what you have above. Just to repeat, I would expect the FL at best to bring you whatever economy you get when pulling what you have empty. The FL might be able to do the same, but loaded. Is that enough for you? What do you think that is on a 32' trailer?
Paul III
Old 10-07-2011, 06:11 PM
I bought the diesel back in 1995 when diesel fuel was around 35 cents cheaper than regular gas. Back then it made sense to pay the extra few grand for the diesel option as you would recover the money in fuel mpg savngs in around a year.
These days it doesnt make any sense, since diesel costs so much more than premium gas and you never recover your costs.
Old 10-07-2011, 06:18 PM
Chevy454 Chevy454 is offline
We've had a couple 8.1L rigs and 3 generations of Duramax trucks, and here are the general numbers I use when people ask about cost differences...
I've driven the same route to/from work (55mph speed limit, open highway) for 3+ years now, with 3 different 4x4 trucks...and I've kept nearly every fuel receipt I've ever gotten in this time. The 8.1L was a ccsb, and generally got 11-12mpg as a daily driver, and would *occasionally* slip in a 13mpg if I ran over to West Plains (25 miles of 65mph 4-lane)...and this was with an ecm tuned for mileage (Wait4Me). My LB7 Duramax was a cc/drw, and it would see 16-18mpg, but was a chronic injector eater as are all LB7s (unfortunately). My current truck is an LLY ccsb, and sees 15-17mpg, but will slip in an 18mpg if I see the 4-lane...dad's '06 gets nearly identical to my truck. Having said that, here are some numbers I use when people ask about cost to drive...
8.1L = $3.25/gallon, 12mpg = 83.3 gallons per 1,000 miles = $270.72 (regular)
8.1L = $3.55/gallon, 12mpg = 83.3 gallons per 1,000 miles = $295.71 (premium)
LLY = $3.75/gallon, 17mpg = 58.8 gallons per 1,000 miles = $220.50
The higher the fuel prices are, the more savings you'll see from the Dmax...plus, you can easily add a tuner that will gain mileage/power at the push of a button on the Dmax, versus the gas truck which will only see marginal gains. But, aside from the higher initial buy in price (you can really tighten it up if you buy used), you have the additional cost of 2 more quarts of oil at service time plus the price of a fuel filter every 15k miles with the Dmax. I loved my 8.1L, but my Dmax just does pretty much everything better...
Old 10-07-2011, 06:33 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Smokey</div><div class="ubbcode-body">Over the years I been getting bigger and bigger and bigger trailers. Started out with a Haulmark which was ok because I didn't know any better.
</div></div>
The problem(!) is that's where your torque peak is on a Duramax, which means you'll get your best mileage in that neighborhood...
(all stock Dmax trucks have 3.73 gear and roughly 30.5&quot; diameter tire from factory)
LB7 = .71 5th gear, 1800rpm peak = 62mph
LLY = .71 5th gear, 1600rpm peak = 55mph
LBZ = .61 6th gear, 1600rpm peak = 64mph
LMM = .61 6th gear, 1800rpm peak = 72mph
LML = .61 6th gear, 1600rpm peak = 64mph
Old 10-07-2011, 07:23 PM
RAIIIT/A's Avatar
RAIIIT/A RAIIIT/A is offline
My '05 GMC Duramax gets 15-16 towing(open car trailer) or empty.... driving like an idiot. The truck has an Edge products programer(which I keep cranked up.. LOL) aftermarket exhaust and an Airaid air intake. I am also running a 285/70R17 tire. The truck turns a mid 14 1/4 mile and pulls like a frieght train...
Old 10-07-2011, 08:04 PM
Not pulling the trailer, on the highway I'll get 20+ MPG with the diesel......Pulling the trailer I probably average 13-14 MPG.........The added plus with the diesel is that with the Torque, you basically don't know the trailer is behind you.....so, the driveability of the Diesel is way past that of a Gas engine........I've got a 2006 LBZ, maybe the new ones are better....
