1959 "P" CASE WITH 4.88 GEARS. PART # 3788812 DATED K258
THIS HAS BEEN IN STORAGE FOR YEARS AND WAS A WORKING UNIT. BUT SHOULD BE TAKEN APART FOR CLEANING ETC. IT DOES ROTATE FINE, GEARS LOOK GOOD. CARRIER IS NOT BEAT UP. THE CARRIER IS CAST # C 30743. CANT FIND STAMPED RATIO OR ASSEMBLY STAMP, CAN ONLY MAKE OUT WHAT IS AN N,M OR Z ? LIGHT STAMP. THERE IS NO PITTING ON CENTER SECTION AND CAST NUMBERS AND P CODE LOOK GREAT. THIS WILL CLEAN UP NICE . $750 SHIPPED First I will take it. Money order Lower 48 only ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
What is the assy date and code for the original ratio? They are stamped on the RH front side of the unit.
It now has a 3 series carrier with a thick replacement ring gear. thanks Verne |
Cleaned up case,only thing I can see is what is an N,M or Z nothing else and there is no pitting.Thanks Ed
still available
