Old 07-23-2016, 01:45 PM
XXXGoldL34M20's Avatar
Default 302 327 350 CE Sm Block 1971 3959512 Standard Bore
This is a virgin stock bore 3959512 Chevrolet Small Block. These were made for Chevrolet 302-327-350 motors under service or warranty with a 4" Bore with 2 Bolt Main Caps. The outcome of the cubic inches depended on what crank you would use. It is a medium journal CE motor that is above average on thickness and other critical areas as it has the front casting number of 020 on the front of the block which indicates High Nickel content in the cast metal. I say it is one of the best stock block foundations to buy for building a great small block chevrolet motor. Motor is dated February 1971 so it would be perfect for a warranty replacement block for 1971 1970 or 1969 models like the Camaro Chevelle SS Corvette Nova Impala etc.... That came with the two bolt mains.
Casting numbers 3959512 B41 (February 4 1971), Starter base number 02 71 V (February 1971) Front of the block has casting numbers 1-020-G51.
There is no Shipping on this Motor, Pick up in person only.
$800
A Danny Donald Tarquini Consignment
