Old 08-01-2016, 10:40 PM
musclecar fan musclecar fan is offline
Default M20, M21 or M22?
Can Anyone ID this by looking at the gears? M20, M21 or M22?
Old 08-01-2016, 10:49 PM
L72Chevelle L72Chevelle is offline
Default Re: M20, M21 or M22?
The two lines on the cluster gear would mean M20. Does it also have two lines on the input shaft?
Old 08-01-2016, 10:58 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
not an M22...
Old 08-01-2016, 11:02 PM
No lines, fine spline.
Old 08-02-2016, 12:02 AM
Ls6 Ragtop Ls6 Ragtop is offline
That's an M20 wide ratio. Count the teeth on the input gear. Should be 21 teeth which identifies it as 2.52 to 1 wide ratio 4 speed.
That's a replacement input shaft which was available with no spline identification or "rings" located on the spline.
Chris
