Old 12-20-2016, 12:30 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Default Valve Spring Compatibility
Lunati recommended their 73121 springs for my new cam. I already have some PAC 1924. All except the rate looks pretty close to me, but admittedly I'm guessing. Any thoughts on whether the PAC springs below would be alright to substitute for the Lunati springs below? Cam specs at the bottom and this is all going in a 494ci (4.30"x4.25&quot. Thanks.
Lunati 73121 Dual with Damper
Install Load: 142
Install Height: 1.940"
Open Load: 402
Open Height: 1.250”
Coil Bind: 1.089"
Rate (lbs/in): 377
Lift Max (in): .690
O.D. Outer: 1.540"
I.D. Outer: 1.140"
I.D. Inner: .794"
PAC 1924 Dual with Damper
Install Load (LB): 144
Install Height: 1.900”
Open Load (LB): 403
Open Height (in): 1.300
Coil Bind Max (in): 1.125
Rate: 431
Lift Max (in): 0.650
OD (in): 1.540
ID (in): 1.140
Inside Spring ID (in): 0.754
Voodoo 20110713 Cam
Advertised Duration (Int/Exh): 292/300
Duration @ .050 (Int/Exh): 241/249
Gross Valve Lift (Int/Exh): .625/.625
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 2600-6600
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 12-20-2016, 03:49 PM
L78steve L78steve is offline
Default Re: Valve Spring Compatibility
They look compatible to me.
Old 12-20-2016, 03:51 PM
earntaz earntaz is offline
Dave -- they look pretty much the same ... just make sure to check for coil bind. TAZ
Old 12-20-2016, 04:14 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">They look compatible to me.</div></div>
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Dave -- they look pretty much the same ... just make sure to check for coil bind. TAZ</div></div>
Thanks guys. I was mainly concerned with the Rate. 377 vs 431. I'll double check the .036&quot; difference in coil bind too. A reputable machine shop is setting the heads up this week, so hopefully they should be good to go. I just didn't want to give him something that isn't compatible.
-Dave
Semper Fi!
Old 12-20-2016, 04:55 PM
HawkX66's Avatar
One more question... Can someone confirm the valve spring &quot;max lift&quot; refers to the max cam &quot;gross valve lift&quot; it can handle?
-Dave
Semper Fi!
Old 12-20-2016, 05:38 PM
The higher rate spring will be a benefit at higher RPM's. If your not running at High RPM's use the lower rate spring.
Old 12-20-2016, 05:48 PM
HawkX66's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">The higher rate spring will be a benefit at higher RPM's. If your not running at High RPM's use the lower rate spring. </div></div>
Thanks Steve. I doubt I'll be seeing very high RPMS, but I already have the higher rate springs. I'm sure less than 6k rpms. My 69 isn't set up for that kind of power and wouldn't handle all the torque and hp right now. If it isn't detrimental to my cam I'll just go with them so my buddy that is buying the parts doesn't have to spend another $120 or so on springs. He's already up over a grand on the cam and lifter set alone to make my motor what it was supposed to be when I bought it. Long story from another thread, but he got screwed by a builder and didn't know it until I bought the motor from him.
What do you think about the lift question?
-Dave
Semper Fi!
Old 12-20-2016, 07:55 PM
Gross is before loss. Total is what you end up with. If you have a clearance of .030 subtract that from gross. So at .625-.030=.595
Even with Hydraulic there will be some lift loss.
Old 12-21-2016, 02:29 PM
EZ Nova EZ Nova is offline
I think you'll be fine. Or possibly take out the damper and get the rate down some too. I wouldn't second guess this with solid just not sure as I've never ran hyd cam stuff.
Dave BTW that cam only &quot;works&quot; to 6200 anyway. 2600-6200
'78 Z28 4sp being restored
'70 W30 convert TRIBUTE
'66 CANADIAN Nova SS Race Car
'69 FIREBIRD Tubbed Racecar
Old 12-22-2016, 01:54 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
Dave, the 1924 are the springs I gave in my motor, they are installed at 1.92
