Old 03-26-2017, 05:35 PM
DannyD DannyD is offline
Default 15 x 7 Torque Thrust D
Folks, looking for fitment advice...I have a 69 Nova SS. I want to run 15 x 7 torque thrust D wheels. Tires will either be a 215 75 15 or 225 70 15.
Any interference issues? Anyone running this combination? Thanks. Dan
Old 03-26-2017, 07:48 PM
BJCHEV396's Avatar
Hi Dan,I had 15x7 Cragars with 225/70/15 tires on my 1970 Nova with no issues.
Old 03-26-2017, 08:53 PM
Thank you.
Old 03-26-2017, 11:22 PM
F or G70-15 Polyglas would look awesome. G70-15 are a tall tire...
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 03-27-2017, 12:50 AM
ssl78 ssl78 is offline
Nova do not like 15 inch tires in front they will rub unless the front end is lifted.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 03-27-2017, 02:05 AM
ORIGLS6 ORIGLS6 is offline
FWIW, I'm running 14" x 7" (Vintage)Torque Thrusts on my '69 Nova with F70s. The wheels have a 1˝" positive offset. I have to run air shocks on the rear to clear the outer right side wheel well lip. I was told by a knowledgeable Nova guy from Iowa that I would have clearance issues, most likely on the Right side,..... and as usual, he was right.
Old 03-27-2017, 12:01 PM
Thank you everyone
Old 03-29-2017, 01:20 AM
cwc's Avatar
cwc cwc is offline
I ran 15x7 torque thrust TTO on rear with 235/70 with no rubbing. 15x5 on front with 205/70.ill try and dig up a pic
1967 SS427 4 speed triple black survivor-sold to a good home
1969 nova SS396 L78 4 speed triple black survivor
1970 camaro SS350 citrus green,Dad bought it new!
1968 chevelle ss396 L34 M21 KK rear all born with
1972 formula 400 M22
Old 04-05-2017, 03:02 AM
Tommy Tommy is offline
these are 15X7 D's on my 68. The front tires are 215/65 and the rear are 245/60. I trimmed the rear wheel lip slightly on both sides and raised the rear slightly with shackles (trimmed). The front end sits a little higher in last couple pics (on purpose because of deep oil pan) so obviously there was no rubbing then. If I remember correctly I removed the top bolt on both sides of the front wheel well before I raised front end. The tire rubbed that bolt so I eliminated the source of the problem.
Drove it hard through Deals Gap without issue.
Tommy
Old 04-05-2017, 11:40 AM
wheelhop wheelhop is offline
Looks good Tommy! like the tow tabs
