Old 08-10-2020, 04:18 PM
BmStang BmStang is offline
Default Schiefer GM Aluminum Flywheel 10.5 & 11' clutches
Vintage Schiefer GM Aluminum Flywheel 168 teeth Fits 10,5 & 11" clutch BBC,SBC Never Installed.Drilled for both 10.5 clutch (5-13/16" hole spacing and 11 5/8 diameter) 11" clutch (6-5/16 hole spacing & 12-5/8 diameter) 14" Outside diameter. 2.475 approximate diameter center hole. Weighs 11 lbs. Stamped #824 &2208 Casting Pat. 2719438 and Harvey Aluminum Teeth are excellent. Face has shelf wear scratches . I would do a skim refacing to make sure it is true. 450.00 Plus shipping
Attachments - The Supercar Registry F588AA90-7B55-417A-A12A-202CA06E68E6.jpg ED01C046-418A-4CBD-A8AD-520E0D52826A.jpg DE7EDFD3-41AB-471C-86C8-D98D1A13F0A7.jpg CAF1CC71-AD38-4F2E-AB95-633767142045.jpg
