Old 03-09-2021, 01:27 PM
XXXGoldL34M20's Avatar
Arrow 1968 Chevelle Camaro Corvette Smog Pump/White Fan Green Relief Valve 7801149
7801149 Smog Pump with uncracked White Fan, One year only 1968 Air Valve with correct light green relief plastic insert. My studies show this is correct for 302 Z28 and 396 or 427 Big Block motors for Camaro Chevelle or Corvette.
Stamped 17381Y which is June 21 1968 1st Shift Y is manufactures plant code, first number is stamped very lightly and barely visible and factory stamped it away from the machined pad. Casting number on the back is 153 June 1 1968. Still has front pulley "BP" bolts on there as well.
Spins smoothly and I believe this has never been restored and still has air plates inside.
$450 USD with FREE Shipping.
