Old 03-07-2023, 04:07 AM
scuncio scuncio is offline
Default Unknown Special Paint COPO Chevelle?
Going out on a limb here...but I think this may be a COPO Chevelle.
Compare its trim tag to my previous COPO...now owned/restored by Jeff Latondress. Similar body numbers for the same build timeframe, and the special order code is fairly close.
Link to 1969 Chevelle eBay auction
Auction car trim tag, VIN 136379B396221
My old car, VIN 136379B394091
The Following 9 Users Say Thank You to scuncio For This Useful Post:
69 Post Sedan (03-07-2023), dustinm (03-08-2023), GotGrunt (03-07-2023), Hawkeye (03-07-2023), juliosz (03-07-2023), olredalert (03-07-2023), PeteLeathersac (03-07-2023), ruralrte66 (03-07-2023), Woj (03-07-2023)
Old 03-07-2023, 04:17 AM
AnthonyS's Avatar
interesting…
Old 03-07-2023, 01:25 PM
Woj's Avatar
Woj Woj is offline
The seller says it has a 4:10 gear. Would be interesting to find out the rear end code.
Old 03-07-2023, 03:59 PM
GotGrunt's Avatar
GotGrunt GotGrunt is offline
I was thinking the same thing. I also see a 3/8” single fuel line.
The Following User Says Thank You to GotGrunt For This Useful Post:
Woj (03-07-2023)
Old 03-07-2023, 06:14 PM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Default Axle code
Seller and I went back and forth today trying to get a photo of the code. The car was raced early in its life and does show signs of traction bars welded to axle and frame. Tube has no code stamped in it probably due to grinding welds off. Cast date looks to be 1970 so axle is not original anyway.
The Following 3 Users Say Thank You to Hawkeye For This Useful Post:
dustinm (03-08-2023), GotGrunt (03-07-2023), Woj (03-07-2023)
Old 03-07-2023, 11:30 PM
SS69chevelle SS69chevelle is offline
it might be possible that the body tag was added to the car at some point in its life. i would verify the vin as well with any convins on the firewall. something isnt matching up in my list. the body tag shown should be in the late 393xxx or early 394xxx range not 396221. if the six digit number 192612 was 195612 it would fit my list- maybe a bad stamp on the third number? tag rivets dont look old to me but it might just be me. Thanks for posting the info.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following 5 Users Say Thank You to SS69chevelle For This Useful Post:
69 Post Sedan (03-08-2023), dustinm (03-08-2023), Pro Stock John (03-07-2023), ruralrte66 (03-08-2023), Woj (03-08-2023)
Old 03-08-2023, 12:18 AM
The rivets do appear to have been pinched back in to allow the tag to be removed with them intact and not spread out again after. The centers look strange.
Old 03-08-2023, 12:41 PM
Woj's Avatar
Woj Woj is offline
Just looking at some trim tag data of mine, the body number is very close to a 6A car that I have data on, but the VIN is only off by 1500 on a 6D car that I have data on. This car's VIN is only off by 143 numbers from a 7A car. FWIW.
The Following User Says Thank You to Woj For This Useful Post:
