Any Experts out there that can I.D. the application ?
67 Z-28 cowl plenum air cleaner
[Edited by CopoCrunkus (03-17-2002 at 08:45 PM).]
66 454 Chevelle 67 396 C-10 Pick up 69 427 Camaro 95 LT-1 Impala SS |
the early Chevelles also had the same unit if i remember right
IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE, FEEL FREE TO STAND IN FRONT OF THEM !!! |
1987 Yugo I will give you $10.00 for it.
I think that is off a big block Chevelle. If I remember right if you look in the plenum a small block has 3 dividers where a big block would have 4 dividers. The easiest way to tell is to put it on a small block if it fits it is a small block one. A big block one will not fit on a small block without hitting the distributor. I know this because I had a cowl plenum 68 z with the cowl plenum air cleaner missing and had bought the wrong one. The other way to tell is if you have the duct a Camaro duct will have a shelf on it, the Chevelle is flat across the firewall face.
69 RS SS L78 conv 69 RS SS ZL1 69 L78 Chevelle conv 69 L78 Nova 69 L34 Nova 67 SS Chevelle 73 Trans Am |
The Weird part is the Location of the Dent in the side. If you look at the dent in relation to the Plenum coming off and the centering notch for the carb. The dent points to drivers front corner. A 68 Camaro smog pump isn't over there. I am guessing it is for some type of Chevelle but would like to know the exact application.
66 big block Chevelle
