I have another 5-blade fan stashed away, probably the nicest one you'll find. This is the blade only - I don't have the clutch. It has been glass beaded and Epoxy primed and has no damage or evidence of rust pitting whatsoever. Can be used as-is or topcoated with whatever finish you prefer. I would like $1000 which includes shipping to the lower 48 states.
Thanks, Tony |
Are the clutches still available or to hard to find?
1968 LOS Rallye Green Z28 |
I think the original style clutch is hard to find. If you can live with the Eaton style clutch that looks a little different, they are available with the correct offset and bolt pattern.
i will check into that today
The eaton clutches are not even close in appearance to the originals and yes the originals are hard to find. I saw a fan alone sell for $800 and the last clutch and fan went for $2250.
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
