Old 07-07-2021, 03:16 PM
Zedder's Avatar
Zedder Zedder is offline
Thanks Mike! That tip likely saved me a bunch of time!
Mark
1996 Carrera & 1993 Fat Boy
Old 07-08-2021, 09:29 PM
1967Z28's Avatar
1967Z28 1967Z28 is online now
The replacement heater cores these days aren't the same thickness as the originals. What are people doing to compensate?
Old 07-08-2021, 10:15 PM
X66 714's Avatar
X66 714 X66 714 is offline
I took my original to a radiator shop. They had no problem rebuilding it. More money but better...Joe
Old 07-09-2021, 03:49 PM
ELEFUNTMAN ELEFUNTMAN is offline
Mine is not a concourse car, I purchased an aluminum one when original types were not to be found, very thick and stout. Fit great with no worries of hurting it. Can't see it when installed!
The Following User Says Thank You to ELEFUNTMAN For This Useful Post:
1967Z28 (07-11-2021)
  #15
Old 10-31-2021, 02:10 AM
Zedder's Avatar
Just following up on this thread. I purchased 2 brass cores from Classic Industries and sent them to a friend’s shop to install them along with a few other parts. When they opened the boxes, Classic had sent aluminum cores that looked nothing like the one that was in the car. Unfortunately, they had already installed the core before they sent the first pic below, so I asked them to remove it and put in another or fix the original. Anyway, it appeared that the original core was not leaking and the mechanic thought it was a tiny crack in the hose that was causing the leak. So, we put the old core back in and they changed the hoses. After about 25 miles, it’s leaking again, so I bought another core and new correctly marked hoses (they were out of stock during the last repair).
This time I got the core from Camaro central. It is brass and 2 inches thick rather than 3 inches like many of the current repops. I also got new clips and tower clamps. While the car is at the shop we are going to replace the repop spiral shocks and rear axle cover gasket. The car should be ready to go for the next driving season!
Mark
The Following User Says Thank You to Zedder For This Useful Post:
PeteLeathersac (10-31-2021)
  #16
Old 11-01-2021, 11:58 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is online now
Aren't the spring ring clamps (vs. tower clamps) correct for heater hoses through sometime in 1968?
Jake Dykstra
Dykstra Motorsports
Old 11-01-2021, 12:21 PM
Zedder's Avatar
Yes, for 67, but I don't know about 68. Owner before me took them off after they were used when the car was first restored. He didn't trust them and I agree. Went with new towers as the old ones were a little oxidized. If I was going to show the car, I'd put them back on for the show.
Mark
Old 11-01-2021, 01:35 PM
1967 4K's Avatar
1967 4K 1967 4K is online now
Default Spring clamps
I have the spring clamps on my car, never had a leak. Kinda aggravating to put on. I took an old pair of cheap pliers and used a Dremil tool to make indentions in them so as to keep it from moving as you open them.
Richard
Richard
1967 Camaro SS 396/375 4K
Old 11-01-2021, 01:47 PM
I have 2 pair of spring ring pliars (old) spring rings work great, never had a leak and prefur them over a tower however I'm an old Mopar guy!
Old 11-01-2021, 08:29 PM
wundercluck wundercluck is offline
Repop Spiral Shocks...don't get me started.They look good but ride like crap.
