67 Camaro 12 Bolt Rearend 69 456 gears posi
Selling a 67 Camaro 12 bolt rearend that has a 69 posi and 69 456 gears in it. It is stamped QS. The traction control bracket has been removed. The spring perches have been moved in to fit 66-67 Nova. Whoever did it did a clean job on removing and replacing the pads. A good candidate for a tri-5 or other build. The price is 1200 PP FF or cash and carry. I will pallet and ship at your expense. Might be a good time to try out the Pirateship.com mentioned on another thread. Larry 5203492337
Any idea how much that would cost to ship to 11570 LI NY? Thanks, Mark
Something like that would be Yellow Freight (now YRC Freight) shipped terminal to terminal on a pallet. I sent Berby a BE rear 7 or 8 years ago and it was only about $125 to $130 bucks. Expect it to be higher now.
But.... it is only cheap if you schedule it on line. It is more than double if you just drive to the terminal and try to ship.
Can only seem to find posts about 10yrs back and seems like 125/150 was the range to ship. Thanks Lynn.
COPO Posi unit and gears.?
70 L78 Nova Fathom Blue,Bench, 4spd, F41, 3:55 71 Porsche 911 Targa |
Hello, I am not sure it does have the larger window in it. I guess I should take it out and counter the spider gear teeth is that how to tell. Larry
