Old 05-14-2024, 01:30 AM
MR SHORTY MR SHORTY is offline
Default DZ Stamped engine in a C10
I have a 350ci in my 1969 C10 or so I thought. It is stamped V0313DZ with casting code 3970010. The engine is in the running truck so difficult to see anything else. Would you say this is actually a 302ci Z28 engine?
The Following User Says Thank You to MR SHORTY For This Useful Post:
olredalert (05-14-2024)
Attachments - The Supercar Registry V0313DZ.jpg Eric 5.jpg Engine E 20 9.JPG Engine casting code.jpg
Old 05-14-2024, 01:59 AM
Lynn Lynn is online now
Would suspect a restamp. Have never seen an 010 block before April.
Machine marks are running left to right. Should be N & S as broach marks.
Would bet that if measured from the crank centerline, the deck is less than 9.025 inches, indicating it has been decked.
Position of the stamp is not correct.
I am certain others will chime in.
Old 05-14-2024, 11:43 AM
I wonder what is the casting date on the back of the block? Should be a week or so before 3/13.
Old 05-14-2024, 03:02 PM
Billohio Billohio is offline
Looks like the broach marks are running the wrong way and it is not a similar stamp to my DZ the week before
Bill
Old 05-14-2024, 05:35 PM
Check the casting date. If it is pre March 13, 1969, I believe it will be the earliest known 010 block out there. I have never seen one dated prior to April, 1969. Not saying they don't exist. Just haven't seen one.
Old 05-14-2024, 08:00 PM
FTC's Avatar
FTC FTC is offline
If that was an MO block found in a Chevy truck,...it could be mine.
Old 05-14-2024, 10:54 PM
Jonesy's Avatar
Jonesy Jonesy is offline
That is a restamp for sure. It is not consistent with other legit stampings.
Old 05-15-2024, 12:15 AM
Will try and twist around to see the casting date. Is there a legit reason an engine gets restamped such as after deck machining?
Old 05-15-2024, 01:01 AM
iluv69s iluv69s is online now
The Following User Says Thank You to iluv69s For This Useful Post:
Big Block Bill (05-15-2024)
Old 05-15-2024, 01:56 AM
WILMASBOYL78's Avatar
Default small block
Why would you restamp a DZ motor and then put it in a pickup truck
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
markinnaples (05-17-2024)
