Old 07-24-2010, 11:04 PM
Z28DL Z28DL is offline
Default Restoring a buildsheet and inspection sheet
My friend is the original owner of a 1970 LS6 Chevelle SS and recently found his buildsheet and an inspection sheet on top of his gas tank. The build sheet is in poor condition and in pieces. You can still make out the LS6 454, Vin, and alot of other information. I am looking for information on how he can flatten, clean and perserve this very important piece of documentation. Any information on how to restore or who can do it would be greatly appreciated.
Thanks,
Dave L.
SoCal
Old 07-25-2010, 12:26 AM
69SSZL1's Avatar
69SSZL1 69SSZL1 is offline
Default Re: Restoring a buildsheet and inspection sheet
Do not try it yourself. This is a job for a Paper Conservator. Look for one thru a museum or Google. They use special methods and chemicals to restore and preserve documents. Some have experiance with Corvette Tank Stickers as well. It is well worth the money for that car.
1962 Oldsmobile Jetfire, Factory all Aluminum V8 Turbocharged and Methanol Injected TURBO ROCKET engine, 4 speed Hydramatic, 4 link rear suspension, 3.36 differential, California car, PS, PB, PW, AC, Jetfire 2 option package.
Old 07-25-2010, 12:28 AM
Dave ngtflyr has done research on this. Give him a holler.
[email protected]
Old 07-25-2010, 01:15 AM
I have cleaned neutralized and preserved many build sheets, the most common issues other than physically being destroyed are Tar and rust. Tar is easy, the rust is a bear as it acidifies the sheet of paper which is how some pulp mills break fiber down from wood chips... this causes the most destruction of build sheets.
Old 07-25-2010, 03:18 AM
Ngtflyr Ngtflyr is offline
Unfortunately I haven't had much success finding an outfit that will take it on. My 69z gas tank buildsheet is very deteriorated, in multiple pieces, and has blackened over time to an unreadable state for most it. I know it can be done, museums restore documents all the time, I figure that is the most likely avenue. Just got to find the right guy. I even contacted a place in NYC that does document restoration and even has a Shelby Cobra buildsheet as an example. They weren't interested in tackling my problem. If anyone has any leads I would be very appreciative.
Dave
Old 07-25-2010, 04:05 PM
x  Baldwin  Motion's Avatar
here is one place that says they can do almost everything with old docs.....
http://www.acapaperrestoration.com/c...problems.shtml
Old 07-25-2010, 10:38 PM
67L78conv 67L78conv is offline
Many moons ago when I used to own a comic and collectible store I used to use the services of a very nice woman named Susan from The Restoration Lab in Boston. Although she primarily works with comics she used to be willing to work with other types of paper material. Prices were very reasonable back then but I have not had use for her services in over 10 years so cannot say for current work and prices. When I was using her for work though it was excellent every time with good turn around. You may want to give her a try as the damage to your sheet is not very different than the damage seen on many comics with the exception of the tar that is.
Their website is - http://www.therestorationlab.com/
If they are not interested in tackling it, Comic restoration people are a decent avenue to look into as they often deal with many different types of paper restoration issues and if they are good can handle just about everything.
Old 07-26-2010, 12:01 AM
luzl78 luzl78 is online now
if the buildsheet is still on the tank just leave it on the tank and don't touch it. put a new tank in. the original sheet is just a confirmation of the value of the car so i don't think it matters if it's on the original tank. it only matters when you sell the car.
Old 07-26-2010, 03:14 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: luzl78</div><div class="ubbcode-body">if the buildsheet is still on the tank just leave it on the tank and don't touch it.</div></div>
If it's still on the tank (and the way I read the original post in this thread, it appears that's the case) it will continue to degrade, even if the tank is removed from the car....by the time the owner may want to sell the car, it may be completely worthless. I think the idea here is to do something that not only may improve it's readability, but prevent it from further degradation.
Bill Pritchard
Old 07-26-2010, 03:41 AM
It's not on the car...I have seen pics of it [img]<<GRAEMLIN_URL>>/beers.gif[/img]
