Go Back   The Supercar Registry > Sponsors > Nickey-Chicago
Old 07-11-2017, 11:58 PM
Stefano Stefano is offline
Default Modern LS7 built for boost for sale
Modern NicKey Performance Stage III LS7 Long Block built for boost for sale.
We had a customer back out / delay a Stage III engine upgrade / build. So we have a fresh custom built engine with all of the best parts, machining and assembly available.
Good for any modern based LS equipped vehicle and/or a restomod or protouring application.
GM LS7 block and heads.
CNC Ported Heads and new stainless valves along with new valve guides.
Block with new thicker sleeves for boost / stock bore and stroke so 427ci
Forged and balanced rotating assembly
Custom DDS Pistons / coated crown and skirts
Oliver Rods
Callais Dragon Slayer crank
ARP main studs
ARP head studs
custom Composite head gaskets
You pick custom NicKey Specs Cam, dependent on type of forced induction.
Had planned to run 1,200 crank HP with twin turbos.
$19,500.00 plus choice of forced induction.
Old 07-13-2017, 11:21 PM
DW31S's Avatar
DW31S DW31S is offline
Sounds like deal to me!
Old 07-14-2017, 02:57 PM
There is more to our engine pkg (like the sleeves) than most other builders and you will find our prices very competitive and usually less than other major players in the LS world, plus its a NicKey and most do not offer anything which sounds like our cams ; )
