Old 10-22-2019, 03:35 PM
Default Steering Box Adjustment
----It seems as if my memory is, once again, alluding me. The non-power steering box on my 67 442 has too much play. After loosening the nut, which way do I adjust the stud???........Bill S
Old 10-22-2019, 04:04 PM
clockwise to tighten.
olredalert (10-22-2019)
Old 10-23-2019, 11:13 AM
Igosplut's Avatar
Igosplut Igosplut is offline
Make sure the box is centered when you adjust it.
WOT
The Following User Says Thank You to Igosplut For This Useful Post:
olredalert (10-23-2019)
Old 10-23-2019, 09:17 PM
Front tires should be on the ground, correct?? Or in the air.
Old 10-25-2019, 02:33 AM
ssl78 ssl78 is offline
I usually have them in the air so you can turn it lock to lock to see if it binds
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
olredalert (10-25-2019)
Old 10-25-2019, 10:25 PM
Thanks John!!
