Old 12-27-2022, 11:37 PM
lbnaz lbnaz is offline
Default 67 Camaro 12 Bolt Rearend 69 456 gears posi
Selling a 67 Camaro 12 bolt rearend that has a 69 posi and 69 456 gears in it. It is stamped QS. The traction control bracket has been removed. The spring perches have been moved in to fit 66-67 Nova. Whoever did it did a clean job on removing and replacing the pads. A good candidate for a tri-5 or other build. The price is 1200 PP FF or cash and carry. I will pallet and ship at your expense. Might be a good time to try out the Pirateship.com mentioned on another thread. Larry 5203492337
Attachments - The Supercar Registry IMG_9999[1].jpg IMG_9848 (1).jpg IMG_9847[1].jpg IMG_9846[1].jpg
Old 12-28-2022, 10:50 PM
wannarun70 wannarun70 is offline
Any idea how much that would cost to ship to 11570 LI NY? Thanks, Mark
Old 12-29-2022, 02:27 AM
Something like that would be Yellow Freight (now YRC Freight) shipped terminal to terminal on a pallet. I sent Berby a BE rear 7 or 8 years ago and it was only about $125 to $130 bucks. Expect it to be higher now.
But.... it is only cheap if you schedule it on line. It is more than double if you just drive to the terminal and try to ship.
Old 12-29-2022, 02:40 AM
Can only seem to find posts about 10yrs back and seems like 125/150 was the range to ship. Thanks Lynn.
Old 01-01-2023, 01:34 PM
JRSully JRSully is offline
COPO Posi unit and gears.?
71 Porsche 911 Targa
Old 01-01-2023, 06:40 PM
Hello, I am not sure it does have the larger window in it. I guess I should take it out and counter the spider gear teeth is that how to tell. Larry
