Old 11-08-2005, 07:15 AM
Jayden Jayden is offline
Default TH700
I am looking for some help out there, please. I am wanting to use the stock horseshoe shifter in my 69 camaro, but want to put a TH700 in it. I have talked with a few trans guys and they say the only way to do it would not allow me to put it in 1st gear manually. I have seen a couple powerglide to TH700 shifter conversion kits, but not sure if this would solve the problem. Anyone have any experience with this out there? Your opinion would be greatly appreciate. Thank you in advance!
Old 11-10-2005, 10:35 AM
indyjps indyjps is offline
Default Re: TH700
ive got a p/g shifter that was modified to work with a th-350, i can see if there is any additioanl travel to allow for another notch to be cut. seems like the cable and shifter would have to be allowed to drop down one more notch for this to work, may have to go to an aftermarket cable. pm me ill take a look @ it.
69 camaro
Old 11-10-2005, 09:36 PM
kwhizz kwhizz is offline
Default Re: TH700
Check with Shiftworks......I have a 700R4 in one of my cars and have one of their floorshift kits in it....detent plate, Shift Indicator Lens , new brackets, and shifter cable........they also have a correct ratio adaptor to bolt onto the carb......this is Very Important as is the adjustment of the TV cable
www.shiftworks.com
Hope this helps
Ken
Old 11-11-2005, 05:25 AM
Seattle Sam Seattle Sam is offline
Default Re: TH700
Ditto for Shiftworks, I put their setup in my 65 Malibu SS and the floor shift worked perfectly. They also sold a replacement glass for the indicator that shows all the gears.
Double dittos on the importance of correct adjustment of the throttle velocity (TV) cable...
-Sam
Old 11-11-2005, 09:51 AM
Kurt S Kurt S is offline
Default Re: TH700
TV - Transmission Valve.
Kurt S - CRG
