Old 06-30-2007, 03:36 AM
3macs1 3macs1 is offline
Default Re: 9 inch or Dana 60 ?
My old 427 Nova had a ford 9" 500HP left the line at 5,500 with a trannie break and never hurt it in 10 years. 14.00 by 32 slicks
I would bet Kim your set up was upgraded with a nodular iron carrier and special pinion retainer.The original gray iron set up and caps would explode with 500hp.Also the original traction lock are so thin they would fail catastropicly.
The old bogger was a shade over 500 Hp and she would eat them even after we did the upgrades.We are talking spinning 18.5 wide by 44 tires also with lockers in the front and rear. Something will break eventually.
Old 07-02-2007, 08:51 PM
The car had a mini spool in it for years And ford N case.
Jake is my grandson!!
Old 07-02-2007, 08:53 PM
I ran 5:67 gears in the 1/8 mile tracks and 4:88 in the 1/4 mile tracks.
Old 07-03-2007, 01:05 AM
I figured it could not be stock. Spools are a bit crazy on the street however.
Old 07-03-2007, 01:11 AM
The pin came loose in the mini spool hit bottom of case BOOM. I went to MW spool and 31 spline axles then.
Old 07-10-2007, 09:44 PM
Supergas990 Supergas990 is offline
We ran a 9" in our Super Gas car for years, without ever having a failure. The car weighed 3,750lbs and put out 1,000hp on the motor.
Just don't skimp when it comes to gears, axles, bearings, etc... when it comes to building it.
Blair
1968 L71 Corvette Coupe
1967 L30 Chevelle Malibu
1968 L79 Corvette Convertible (son's)
Old 08-05-2007, 11:26 PM
Mr BB Chevy's Avatar
Mr BB Chevy Mr BB Chevy is offline
for a pro-touring car, a good 10bolt or 12bolt would be fine.
9" or dana for high horse power / heavy car.
Dana 60, 557 gears, 14.5x32's ,3700lb car, same rear for over 20 years.. and a few thousand 1/4 mile passes.
launch1
Launch1 video
Launch2
Launch2 video
1 of 311
Acrobat Signs
Acrobat Tactical
