In my other post regarding oil pressure in my ZL-1 it has been determined that my heads are also in trouble. Water can enter both heat crossover chambers on the heads..this is not good..can this be repaired? The heads will have to come off,.. but the motor is out so now would be a good time. I can feel the hole between the two chambers ..I can do this on both heads if I stick a bent wire just beyond view in the heat port..I was thinking about filling the passage up enough to cover the break using block grout/concrete..may only be the size of a golf ball when done..anyone have experience with this..Thanks
ALbert
1969 9566AA COPO Chevelle M-22 1969 Malibu 489 ZL-1 T-56/4.56 1969 Beaumont 540 th400 3.70 1969 Chevelle 300 Deluxe 427 ZL-1 M 22W 1970 Olds 442 W 30 2 door post 1969 Ply. GTX 426 hemi auto. Blue. 1940 Dodge pick up Durango 4X4 1968 Camaro ragtop LSA ZL1 |
Have any good pics of them?
These guys do excellent aluminum repair. Have a pair of 842's that were in serious trouble. Now they are working fine.
Bob http://www.z28camaro.com/restosvcs.html#Block |
These guys do excellent aluminum repair. Have a pair of 842's that were in serious trouble. Now they are working fine. Bob I know Jerry's work very well..trying to find a "home" cure if possible to save time..Thanks ALbert http://www.z28camaro.com/restosvcs.html#Block [/ QUOTE ]
Have any good pics of them? [/ QUOTE ] no pics as they are still bolted to the block and the piercing into the water passage is on the blind side of the heat crossover curve..I can feel it buyt not see it at least from the intake runner side..maybe after I pull the heads off ALbert
Removal of the exhaust valves may expose the problem .
"Knowledge is good" Emil Fabor 67 L/78 Camaro SS/RS H-H,1W,2LGSR,3SL,4K,5BY. (Sold) 70 L/78 Nova M-21,Black Cherry,Sandalwood Int. 09 Pontiac G8 GT Premium,Sport,Roof. Liquid Red. |
I'm starting to think you should have
left the 307 in it ![]() |
Albert,
Depending (which is a big if) on what type of damage you have, as a "home" cure option you can use a high quality epoxy like Marinetex. I used to work at a cylinder head shop where the guys porting the heads would accidentally grind into a water jacket or breakthrough a port. We saved a lot of heads using epoxy.It takes some practice to fill the hole and grind/smooth it down. And it can be done with good results. As a plan B, we had a guy who could really weld aluminum like a magician. Can you have your machinist take a look at the heads and get an idea of exactly what you are dealing with? Elon
69 COPO Camaro |
Removal of the exhaust valves may expose the problem . [/ QUOTE ] induction/exhaust is fine//problem is in the water jacket/heay crossover
I'm starting to think you should have left the 307 in it ![]() [/ QUOTE ] NO WAY!!
