Old 12-16-2009, 10:00 PM
soonercrew soonercrew is offline
Default Re: Scott's 1st Project.... 72 Z28
just wanted to say thanks to everyone for the positive comments and the critiques! i can't honestly answer on the polylocks, to be completely honest, i had to google it to even see what they were! sorry, not a mechanically enclined type, but im learning!
Old 12-17-2009, 06:39 AM
BARN FIND BARN FIND is offline
Why different polylocks on the intake and exhaust?
Its looking great!
Jason
Will the stock finned valve covers fit with the poly locks on?
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 12-17-2009, 06:55 AM
i assume. they fit fine before...
Old 12-17-2009, 06:00 PM
TimG TimG is offline
Scott, what did you paint the sub frame with? I'll be geting a new sub frame for my Z and I may have it powder coated.
Old 12-17-2009, 06:54 PM
the subframe and rear were painted with 2k ceramic from eastwoods. we did them in the gloss and toned it down a bit.
Old 12-20-2009, 05:16 PM
RichSchmidt RichSchmidt is offline
On my 73 firebird which still has mint undercarrage paint and overspray,the overspray coming from the sides under the rockers was limited in how far the heavy spray went,but under the rear of the car there was much more overspray.It started about 1 foot in from the tail panel under the gas tank and extended well into the area that turns down under the back seat.Your firewall overspray into the trans tunnel looks spot on,it pretty miuch fades in around the seam for the main floorpan.If the red oxide is a litte darker then in the pics,then it should be just right.
My car has been a street race type hot rod all it's life and both me and a lot of past owners spray bombed the undercarrage over the years to clean it up.One day while plotting out a new exhaust system I took a rag with some solvent to the crud and it went right down to the original sealer,overspray pattern and all.Most of the paint was "over sludge" since as far back as the late 70's,so it kind of preserved it well.The paint under the gas tank area peels off in sheets once I get a good edge to dig under.Maybe someday I can post pics of it.I recently went under there with some home mixed rustoleum and redid the areas where the original paint was too crusty.I wiped it down and smoothed it out and mixed red oxide metal primer and gloss black until it made a very close color that I applied with a brush.The car isnt a resto job by a long shot but it is neater then most of these beaten old mules.
Old 02-16-2010, 05:06 AM
few pics of it getting into paint...
Old 02-16-2010, 05:48 AM
70 Forest Green Zee's Avatar
70 Forest Green Zee 70 Forest Green Zee is online now
You're doing a great job Scott....can't wait to see her finished!
1970Camaro Z28
Old 02-16-2010, 06:01 AM
I love the pweter silver color...my Nova was the same color. When we were mixing the painy...I couldn't believe how much brown and green were in the mix!
It's looking great!
Old 02-16-2010, 05:15 PM
-----I love the pewter as well. Looks great on your Camaro. Ordered my 72 Grand Prix SJ that color new and liked it so much I painted my 70 SS454 Chevelle convert the same. For some reason I love it in conjunction with white.......Bill S
