Old 11-25-2009, 01:22 AM
COPO_Anders COPO_Anders is offline
Default 67 Camaro rearend with Chevelle centersection
I talked to a guy today about 12-bolt rearends. He said that the very first Camaro 12-bolt rearends were made using Chevelle centersections because of some delay in production. Is this just made up or is there some truth in it ? Never heard it before.
Something like the first 1964 Chevy II 327 engine-blocks useing the 283 casting (since that 283 was a thickwall-block), so I guess anything would be possible.
Anders Stålklint.
After selling my COPO 9561 I´m now a "postman" with the main project being a 1966 327 2 dr sedan Chevy II.
Old 11-25-2009, 05:12 AM
Kurt S Kurt S is offline
Default Re: 67 Camaro rearend with Chevelle centersection
He means the Chevelle axles with the 4 link top-mounts? BS.
Kurt S - CRG
Old 11-25-2009, 08:43 PM
freddy freddy is offline
I know 67 400 4 speed Firebirds came with 10 bolts with the upper link type mounts cast into the center but not used. They used leaf springs and two I beam traction link bars.
Old 11-26-2009, 12:52 AM
Ok, no Chevelle centersections used on camaros then. Thanks Kurt.
Freddy, is that pic taken on a car that you own ? Does it seem to be factory installed ? Correct dates, no extra welding on the spring perches etc ?
Anders Stålklint.
Old 11-29-2009, 01:43 PM
67 GTO 67 GTO is offline
I've seen them on a non-400 67 as well. Definitely OEM.
Old 11-29-2009, 07:54 PM
Fast67VelleN2O's Avatar
I have seen many 8.2 Firebird rear ends with dual traction bar mounts and coil spring center section. Even on rear ends with 2 series gears and an open.
Day 2 is Life.
Old 11-29-2009, 08:25 PM
budnate's Avatar
budnate budnate is offline
ditto..
Old 12-01-2009, 06:04 AM
Interesting. I never knew that. Swap one into a Camaro and a whole new rumor starts!
Kurt S - CRG
