Old 12-04-2009, 04:07 AM
GaryB GaryB is offline
Default 30/30 302 Cam
What is the best Cam for a 302 Cam? Crane has gone out of business. I was told they were the best, does anyone know of another company to use?
67,68, & 69 Z/28 Camaros
Old 12-04-2009, 08:30 AM
robsgoldZ robsgoldZ is offline
Default Re: 30/30 302 Cam
Rick's has one P/N EP-599, w/ lifters, and says it is original GM. Also, others have used this cam with good success:http://www.compcams.com/Cam_Specs/Ca...d=232&sb=2
Rob
1969 X-33/RS
65-65,712, Nor 03E
Old 12-04-2009, 09:59 PM
thanks I'll check it out.
Old 12-06-2009, 03:57 AM
JohnZ JohnZ is offline
Federal-Mogul/Speed-Pro #CS-118R (cam only) or #KC-118R (cam with lifters). Also used to be available from GM under #12364052 with lifters, but it was made by Crane; the locator might still show some in stock.
'69 Z/28
Fathom Green
CRG
Old 12-06-2009, 08:36 PM
Tommy Tommy is offline
I have Comps version in a smallblock that just came off the Dyno. It sounds great and the numbers look good. Looking at my cam card the part number is 12-673-4. The cam card has a misprint on the lash so if you buy this one don't go with .012/.012... It wouldn't idle at those settings. Comps techs said it should have been .018/.020 . It idles at 1000 RPM now. Hope your not running power brakes though... No vacuum with this cam.
Tommy
Old 12-09-2009, 04:47 AM
Thanks, I'll check it out.
Old 12-09-2009, 04:49 AM
Thanks Tommy, I'm running power brakes.
