Old 12-14-2009, 08:27 PM
W117Monte's Avatar
W117Monte W117Monte is offline
Default Drop Ceiling Questions
Hey guys, I figured if i needed to ask a home repair question, this would be the area to do it in. I have re drywalled our basement, and painted it, but now my old Drop ceiling tiles and track look very dingy and bad against the newly painted walls. Has anyone ever painted the tracks and the ceiling tiles while the ceiling is still up? i figure some flat white would look good. Replacing the track and the tiles is NOT an option. Thanks!!
Old 12-14-2009, 08:31 PM
flyingn's Avatar
flyingn flyingn is offline
Default Re: Drop Ceiling Questions
yes you can. Remove the tiles and either roll or spray paint the t bars..Its done all the time
Frank Szymkowski
Old 12-14-2009, 08:50 PM
Make sure you give the tiles & T-track a thorough cleaning first.
I just did this in a basement where a smoker lived,and found that nicotene stains bleed through later on if you don't.
Old 12-14-2009, 09:56 PM
ORIGLS6 ORIGLS6 is offline
KILZ for the tiles.
Old 12-14-2009, 10:42 PM
Pulnaway Pulnaway is offline
I second the KILZ, but be sure to use the enamel and not the oil base. Oh and lots of fresh air!
Scott
Old 12-15-2009, 01:37 AM
x  Baldwin  Motion's Avatar
KILZ for the tiles.
or Zinsser 123
used this on a brown to white trim conversion in a cigar smokers house.
Old 12-15-2009, 01:49 AM
wannarun70 wannarun70 is offline
the Zinsser works pretty good. Used it a few years back. And look it comes in two colors, white and blanco [ QUOTE ]
KILZ for the tiles.
or Zinsser 123
