Old 02-15-2010, 06:07 PM
chads454Ls6 chads454Ls6 is offline
Default Re: Hoist/Lift Selection
Get a 4 post with the sliding jack. You can change tires etc easily. When these things came out it really advanced 4 posts
Charley,is that jack hydralic or a hand jack?
Old 02-15-2010, 06:28 PM
It is hydraulic that you hand pump. Basically it is a porta power pump hooked to a scissor jack. They also sell ones that are air over hydraulic that you hook a air hose to that uses a butterfly valve. They work great. The lifting arms slide in and out for width and they have extensions that space the pads up.
Old 02-15-2010, 06:37 PM
edcar70 edcar70 is offline
I own an automotive repair shop and the best lift I have found to work on cars is a Rotary 2-post 9000# lift. the 4-post lifts require a lot more room. the two posts require a small foot print and make it alot easier to work under the car. The only reason I have a drive on is to do alignments. The rotary lifts are easy to install and cost around 3500 to 4000. just my opinion. ed
1970 Camaro L-78
1970 Chevelle L78
2015 Z-06, 2008 Z-06
Old 02-15-2010, 06:48 PM
I purchased the backyard buddy with the jack that hooks to the hydralics of the lift and it was 1700 bucks! I would have purchased the hand pump one if they had it. I do not know if they sell the handpump one anymore
Old 02-15-2010, 07:06 PM
http://www.directlift.com/Four-Post-...ories-C18.aspx
Old 02-15-2010, 07:19 PM
That is a good deal
Old 02-15-2010, 09:20 PM
TORONADOXS TORONADOXS is offline
I gotta agree with Ed. Iv'e been a wrench for almost 30 years and worked on a lot of lifts. I work on a Rotary 9000# now and it's great. Rotarys are more money, but are definatly worth it. Very easy to set up.
Old 02-15-2010, 10:24 PM
lzdick lzdick is offline
If you should go with the Rotary lift, I strongly recommend an assymetrical unit.
L.Z.
"...at this point in my life, every day is a Saturday".
Old 02-16-2010, 01:26 AM
I had this discussion on another site. For a two post you need to be sure your slab is probably at least 6" thick. For the average home use i still like the 4 post. harder to make mistakes with a 4 post.
Old 02-16-2010, 01:47 AM
..is that a dare.
