1969 SS/RS Camaro & 409 Impala SS - auction
Okay guys....here is one to check out. This auction is coming up with a 1969 SS/RS Camaro ( Look closely at the engine photos )...This may be a Big Block Camaro!
.....also include in the aution is a 409 Impala SS. Both of these cars would be nice to have. These are not mine....I just stumbled across the link to the auction and started looking a little closer. ...Oh and I did get the cowl tag info on the camaro... Here it is.... ST 69 12437 LOS104740 BDY TR 713 65 B PNT 08E 10108 ....anybody know what "10108" means? ....Now go get it! http://www.auctionbymayo.com/index.p...&ap_sub=fp ...Good Luck! |
Re: 1969 SS/RS Camaro & 409 Impala SS - auction
My guess is that its either I010 or I108 which is the body sequence number they used at Van Nuys. Thats a real early 69 built at Van Nuys. Probably one of the first 400 or so.
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
Engine photo shows a small block with a B&M blower.
curved neck radiator?? AC car...was that standard/optional/available with a small block?
....it is my understanding that ONLY big block with A/C cars
..and COPO cars came with that radiator.... ... ....Hmmm? |
looks like a big block a/c car ...
Jim R Scottsdale, AZ |
doesn't the upper pipe on the A/C box turn toward the air cleaner on a BB?
BB AC goes away from the eng, it's a tight enough fit with that, Small Block AC is turned toward the eng bay. That's a Big Block A/C box as others have stated here.
Dave |
Better tell GM that they made a mistake on UPC C60, sheet D2! Oh, if small blocks turn toward the engine - then they made another mistake on C60 sheet D1.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ngtflyr</div><div class="ubbcode-body">BB AC goes away from the eng, it's a tight enough fit with that, Small Block AC is turned toward the eng bay. That's a Big Block A/C box as others have stated here. </div></div>
Not true...that's a s/b evaporator box. While it seems logical that the POA valve would be on the outside of the box for the larger b/b motor, the General did not do it that way. I have never heard a plausible reason for this. |
