Old 10-20-2011, 10:38 PM
Default Re: Firestone Sport Car 200 E70 15 Tires - Decode
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Edgemontvillage</div><div class="ubbcode-body">Thanks for checking. Seems decoding the SC200 is a lost science. </div></div>
As for Goodyear, I have sources, but not the 'Stones. Wish I could have been more help!!
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 10-21-2011, 01:25 AM
Edgemontvillage's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: x77-69z28</div><div class="ubbcode-body">the reason i ask, is that the repros i bought have a different tread pattern from my orig spare. want to make sure you are getting the real deal </div></div>
I pulled the trigger and bought one of the SC200's in the photos with very light tread wear for use as a (prop) spare. Will take and post a couple of pix when it arrives. I have confidence in the seller.
Old 12-31-2011, 08:25 PM
CamaroNOS CamaroNOS is offline
Below is the production information regarding the decoding of your Firestone Sport 200 tires.
000027UL = May 1969 Akron Plant II
001715RL = Mar 1969 Akron Plant II
001809UC = May 1968 Akron Plant II
I hope this helps!
Paul
Old 12-31-2011, 10:39 PM
Well that sure was nice of you.
Old 01-02-2012, 08:19 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: CamaroNOS</div><div class="ubbcode-body">Below is the production information regarding the decoding of your Firestone Sport 200 tires.
I hope this helps!
Paul
</div></div>
Paul, thank you very much for the information! For future reference can you also post decoding instructions for the Firestone Sport Car 200 tires?
Old 01-02-2012, 10:52 PM
JAD JAD is offline
[quote=CamaroNOS]Below is the production information regarding the decoding of your Firestone Sport 200 tires.
I hope this helps!
Paul
So can you please tell me how CYUYF2GD2400 would decode????Thanks
Old 01-07-2012, 01:45 AM
I hate to tell you but there is no unique sequence in decoding Firestone tires from the 60's and 70's, prior to the U.S. DOT regulations. Tire manufacturers were not required to do so.
The best process is contact Firestone directly and inquire there.
Regards
Old 01-07-2012, 03:34 AM
Steve Shauger's Avatar
Administrator
I hope this helps!
Paul
</div></div>
The original spare in my 9A of 69 built camaro is 001117UL and the YH rim is dated 5/19. Looks like the tire is coded similarly to the May of 69 you have listed.
www.yenko.net
www.vintagecertification.com
Old 07-03-2012, 04:46 PM
Just purchased another Firestone Sport Car 200 tire mounted on an original paint YH wheel. Hoping someone can decode the tire date code (and provide decoding details)?
