Old 11-27-2011, 11:44 AM
COPO_Anders COPO_Anders is offline
Default Optimizing a 1969 Z-28 302 ?
My old friend Hans is doing some work on his Z-28 this winter. Last summer he installed the restored carb that he bought from Eric, and now he wants to get the timing setting, dwell angle etc optimized.
So the question is: what settings are you guys using on your stock 302 engines ?
Anders Stålklint.
After selling my COPO 9561 I´m now a "postman" with the main project being a 1966 327 2 dr sedan Chevy II.
Old 11-27-2011, 12:38 PM
firez firez is offline
Default Re: Optimizing a 1969 Z-28 302 ?
Check out John Zs article over on camaros.org on setting up a 302. I have used it on my 68 z for a couple of years and it works flawless . He has a unique vacuum advance setup.
1968 LOS Rallye Green Z28
Old 11-29-2011, 04:56 PM
Thanks firez, I have told Hans to read John Zs article carefully.
[img]<<GRAEMLIN_URL>>/burnout.gif[/img]
Anders Stålklint.
Old 12-01-2011, 12:18 AM
miket1 miket1 is offline
Send a message via ICQ to miket1
The 302 engine Point Dwell setting is 28 to 32
69 Z28 Burgandy
Old 12-04-2011, 06:40 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: miket1</div><div class="ubbcode-body">The 302 engine Point Dwell setting is 28 to 32 </div></div>
Also, I have my total advance set to 38 degrees before TDC.
69 Z28 Burgandy
Old 12-04-2011, 07:14 PM
Have the distributor done on the machine with a new curve setting. I like Mike t's settings. mine are 30 for the dwell and around 12 degrees on the crank at idle and about 38 total at 2,800 rpm's or so. I run no vacuum advance but some guys differ in that department. I also like the valves adjusted tight.
Old 12-04-2011, 07:15 PM
Thanks Mike, I´ll let Hans know.
Anders Stålklint.
Old 12-05-2011, 04:34 PM
I agree with Sam, I don't like vacuum advance either, I haven't used it since early 1970 with no problems at all,
as per the CRG report, I set my valves at .026 on intake &amp; exhaust, runs and sounds great.
I use AC R 43 plugs gapped at .040. with the original heads.
I hope you find this helpful.
69 Z28 Burgandy
