Old 03-04-2012, 06:27 AM
Camaro Don Camaro Don is offline
Default HQ springs GM# 3955724
Trying to find a replacement set of front coils for GM# <span style="font-weight: bold">3955724</span> tag#<span style="font-weight: bold"> HQ</span>
Old 03-04-2012, 04:24 PM
Default Re: HQ springs GM# 3955724
Strange that the Camaro spring code chart does NOT show &quot;HQ&quot; springs?? It seems the load on these springs are 1830lbs and the rate is 345lbs/inch. I'm trying to match this spring as close as possible. The height is perfect for my SS396.
Old 03-04-2012, 09:49 PM
WILMASBOYL78's Avatar
I think a common BB spring was the &quot;HH&quot;...same as a Nova...of course other things impacted spring selection...including trans options, special suapension, a/c. etc...
Anyway...you should be able to get them from Eaton for your exact application.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-04-2012, 10:02 PM
Thanks Wilma. Yeah I sent Eaton an email.
Old 03-06-2012, 11:47 PM
Heard back from Eaton. Almost a waste of time. They want to sell me the MC 1266 stock spring on their site. 1725 lbs load and 330 lbs/inch was the rate. This is after I gave them the GM#, the spring specs and everything. Any Big Block guys out there ?? What springs did you use??
Old 03-07-2012, 12:53 AM
BARRY BARRY is offline
HI look a ricks first generation
Barry Allan
Old 03-07-2012, 03:23 AM
Thanks Barry. I have been on every Camaro Vendor site I could think of. Not much help. Heartbeat City offers exact replacements. They don't know the specs of each spring though. Go figure??
Old 03-07-2012, 03:37 AM
Donnie's Avatar
Donnie Donnie is offline
Don, do you have the specs for this spring #3952818 GW?
69 SS L78 Chevelle
70 SS 396 Chevelle
Old 03-07-2012, 03:52 AM
Looks like the rate is 320 lbs/inch Here is an old Chevelle thread.
http://www.chevelles.com/forums/arch.../t-258485.html
Old 03-07-2012, 05:19 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Camaro Don</div><div class="ubbcode-body">Heard back from Eaton. Almost a waste of time. They want to sell me the MC 1266 stock spring on their site. 1725 lbs load and 330 lbs/inch was the rate. This is after I gave them the GM#, the spring specs and everything. Any Big Block guys out there ?? What springs did you use??</div></div>
HQ I believe was a late spring as it is in the 1970 Nova chart but not the 1969. It should be the same spec as the &quot;HA&quot; code. Heatbeat City has 3955724 HA The spring height and rates went in numerical order. So 3955723 would be a tad bit shorter and 3955725 a tad bit taller.
Click here to see what the weight specs say your spring should be for L34/L35/L78. Other spring calculators are on my project page.
Greg
