Old 11-12-2012, 04:46 PM
njsteve njsteve is offline
Default Re: The New Project: Part Deux!
Some interesting clearancing on the piston skirts:
And the cause of the oil leak. The rear main had spun and compacted itself so there was a one inch gap in the rope seal, in the cap area.
I used Plastigage and checked the oil clearances on the rods and mains and they were .002. I also checked end play and side clearances and they were in spec as well.
Old 11-12-2012, 06:47 PM
After comparing with some stock rods I had in the garage, it turns out those are stock cast rods with the side beams polished.
Here's the underside of the heads:
The crank:
The soon to be replaced rods and pistons:
and the empty block:
Old 11-12-2012, 11:06 PM
Damn, you don't waste any time.
Old 11-13-2012, 01:36 AM
I needed to do something after being stuck in the dark for 12 days!
Old 11-13-2012, 11:46 PM
L89DRMR L89DRMR is offline
Steve,
I thought when you captioned the photo "The Crank", we would see you.
Seriously, I hope your power stays on for good.
Dave
Old 11-14-2012, 05:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">Got the engine out today.
</div></div>
BTW, Here is today's challenge:
Does anyone know what else is wrong in this photo??? [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 11-14-2012, 06:31 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: njsteve</div><div class="ubbcode-body">[quote=njsteve]
Does anyone know what else is wrong in this photo??? [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] </div></div>
Clutch fork rubber boot installed inside rather than outside ??
Jake Dykstra
Dykstra Motorsports
Old 11-14-2012, 10:20 PM
Very good!
Old 11-14-2012, 10:56 PM
<span style="font-size: 20pt"><span style="font-style: italic">Yikes!!!!! </span></span>[img]<<GRAEMLIN_URL>>/shocked.gif[/img]
