Old 07-07-2013, 04:26 AM
Camaroinaz Camaroinaz is offline
Default Chevy 350 and Other Parts
Motor:
350 four bolt main bored .30 over. Steel crank that is .10 on the mains and .10 on the rods. Motor has never been run. Double roller timing chain. Crane 272 cam with .454 intake lift and .480 exhaust lift 216 degree duration on intake and 228 degree duration on exhaust. Has roller rockers with 1.5 ratio. TRW forged flat top pistons, motor should be about 9:1 compression. Has Edelbrock Performer RPM aluminum heads (2.02 Intake/1.94 Exhaust) and Performer RPM aluminum Intake. Without the extra parts below the motor is $3,000 I will add all of the parts below and it would be $4,000 for everything. I would recommend disassembling the motor and re-lubricating the bearings, etc. before starting as the motor has been sitting for some time.
Extra Parts:
The parts below can go with the motor for the $4,000 price or be purchased separately for the prices below. All parts are new unless otherwise noted.
MSD Pro-billet distributor - MSD Part number 8360 - $200
MSD 6AL Ignition Controller - MSD Part Number 6425 - $200
MSD Blast 2 Coil - MSD Part Number 8202 - $30
MSD 8.5 MM Spark Plug Wire Set - MSD Part Number 35599 - $70
Holley 600 CFM Carb w/ Vacuum Secondary - Holley Part #0-80457S - $250
Hook Competition Headers for 1969 Camaro - Hooker Part Number 2451 - $100
March Serpentine Conversion set-up - Billet Aluminum - $300
Rebuilt starter - $50
Rebuilt Alternator - $25
Pictures available, just e-mail. Camaroinaz@coxdotnet - change the dot to .
Shipping will be actual cost based from zip code 85339 to your door.
