Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 01-18-2014, 09:17 PM
69gmmuscleluver 69gmmuscleluver is offline
Default 5 lug Ford 15" x 5.5'' steel wheel aplication
Need help decoding these 3 15"x 5.5" steel wheels with the Fomco stamp along with M and F 2 stamped near valve stem, D 3 19 also stamped. I'm unsure why but the system won't accept my photos. That said, I can email direct anyone that could assist. Thanks in advance.
Old 01-18-2014, 09:56 PM
Default Re: 5 lug Ford 15" x 5.5'' steel wheel aplication
Photos added.
Old 01-26-2014, 04:43 PM
Sportyworty's Avatar
Sportyworty Sportyworty is offline
The regular 15 inch wheel was a 15 X 5 and the heavy duty/HiPo wheel was a 15 X 5.5. The 15 X 6 was new for 1965.
Now the T Bird also used a 15x5.5 with the large vent holes however they were rivited flame cut as opposed to the welded HiPo center with small vent holes. Look on the inside between beads for some more stampings. Kelsey will have KH or K2 etc. Some will be dated there also. They appear to be T Bird which many use as the HiPo 406/427 based on the large vent openings but hard to tell with out a side by side. Just look for the K stampings and see if they are welded centers. Hope that helps
Old 03-27-2014, 08:09 PM
GPM6367's Avatar
GPM6367 GPM6367 is offline
The M over the small Ford Oval is for manufacturer (I forgot...Motorworks?) and the stamp near valve stem is the date...I think D is April, 19 is 19th and the 3 would be 63 or 73...best I can recall...
1968 Corvette Convertible L71
1969 GTO Convertible
1970 Torino GT 429/SCJ
Old 04-05-2014, 02:28 PM
motorwheel
Old 04-05-2014, 03:23 PM
John Brown's Avatar
Depending where the other end of that tape is, you may have a 14 inch wheel there.
John Brown
