Old 09-28-2014, 12:27 AM
resto4u resto4u is offline
Default 67 camaro body number 32
Can someone explain how this low body number would have that trim tag date, and such a high vin number.
ebay body number 32
67 Z28, 67 RS/SS 396 Canadian, 73 Camaro Z28/LT Carolina Blue
Old 09-28-2014, 01:01 AM
iluv69s iluv69s is offline
Default Re: 67 camaro body number 32
is that 100032?? almost the 100 thousandth camaro?
Old 09-28-2014, 02:22 AM
supercomp 8.90 supercomp 8.90 is offline
theres another firewall in the trunk maybe its a closer match lol!!
Old 09-28-2014, 03:05 AM
1967Z28's Avatar
1967Z28 1967Z28 is offline
If 100032 was the VIN then you would be talking about the 32nd Camaro but this is the NOR body number. The 32nd VIN car would most likely have a 2-digit body number not a 6-digit one. This 03D car was built when the VINs were going from 199,xxx to 200,xxx and from 5-digit body numbers on the cowl tag to 6-digit body numbers starting with a 1.
Old 09-28-2014, 06:36 AM
67rs/ss 67rs/ss is offline
I have a 03 B and a 03 C body numbers 89*** and 97***. So appears to be about right.
67 RS/SS L48 ERMINE WHITE
67 RS/SS L35 BOLERO RED
67 RS/SS L35 BUTTERNUT YELLOW
67 RS/SS L78 0-0
Old 09-28-2014, 04:05 PM
70 copo 70 copo is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 1967Z28</div><div class="ubbcode-body">If 100032 was the VIN then you would be talking about the 32nd Camaro but this is the NOR body number. The 32nd VIN car would most likely have a 2-digit body number not a 6-digit one. This 03D car was built when the VINs were going from 199,xxx to 200,xxx and from 5-digit body numbers on the cowl tag to 6-digit body numbers starting with a 1. </div></div>
Built in assembly sequence was not in VIN order. According to a Norwood Keypuncher--she offered two scenarios to explain this anomaly..Remember after the IBM card is punched the next step was the production scheduling meeting where raw numbers are looked at for inventory metrics vs the RPO content of the days build after that the process creating the body plate (trim Tag) was automated.
IBM card was punched then miss sequenced or lost. When the punched card was found it was inserted into production and built.
The wrong body number was keypunched on the IBM card. (most likely cause)
Old 09-28-2014, 04:57 PM
So if this was body number 32 it would look like 000032 ? Would this be correct?
Old 09-28-2014, 05:27 PM
N100032
Old 09-28-2014, 10:05 PM
bergy's Avatar
bergy bergy is offline
....or the car build was released against a blanket order.
Old 09-29-2014, 12:57 AM
Kurt S Kurt S is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: resto4u</div><div class="ubbcode-body">So if this was body number 32 it would look like 000032 ? Would this be correct? </div></div>
Or NOR 32.
Not 100032, that's mid-way in production.
Kurt S - CRG
