Old 03-10-2015, 12:46 PM
earntaz earntaz is offline
Default Re: Yenko Deuce
Ken -- have you ever spun up one of the W-30 442 400/455 "select fit" engines? Just curious as to how close they were. TAZ
Old 03-10-2015, 01:04 PM
Billohio Billohio is offline
Is the yellow dot on steering box a decal or paint?
Bill
Old 03-10-2015, 01:40 PM
COPO CARTEL COPO CARTEL is offline
It's paint Bill. Dab
Drive it ...Like you STOLE it !!
Old 03-10-2015, 01:42 PM
Scott and Ken...that car deserves the awesome attention that you are giving it. Your detail is impeccable. Congrats and continued success. Doug
Old 03-10-2015, 02:29 PM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
Marlin..Good call on the Metal-ax machine. I'm surprised you know about that machine, most people don't. Back in the late 90s I was helping Paul Pfaff Racing Engines with some Pro Stock development and he just purchased one. I would vibrate Titanium valves and they would cut like butter! I always use that procedure on (Green, New) blocks ,heads ect. But the old stuff with all the heat cycles don't seem to move much.
TAZ, I have not check any OEM Olds Assembly's.
Ken Maisano
Mascar
Detriot Muscle Cars
Old 03-10-2015, 04:56 PM
SS427's Avatar
SS427 SS427 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Billohio</div><div class="ubbcode-body">Is the yellow dot on steering box a decal or paint? </div></div>
That should be a yellow decal with a two letter code. On manual boxes it is a yellow two letter stamp. At least based on my experience.
Rick Nelson
Old 03-10-2015, 05:17 PM
Thanks Ken ...
Old 03-10-2015, 06:49 PM
RST's Avatar
RST RST is offline
Hey Doug,
thank you for the comments, we are washing all parts with soap and water to carefully check for any and all markings, we will document everything. We did this with the Block, but saw nothing, however while Kenny was machining the block, the oils etc have brought out what appears to be some kind of marking in yellow on the side of the block ... a 5 or 6 or maybe even a yellow X ?
Marlin the springs are absolutely original, we will get pictures of both sides when we take them apart and share with you.
Hope you all have a nice day.
1968 1/2 Cougar 428 R Code, Cobra Jet, 4 SPD, Red Interior in restoration at MASCAR to be unveiled by Kevin Marti at the MCACN 2020
1970 Top Secret Very Special Muscle Car in restoration by MASCAR to be unveiled at MCACN 2020
Old 03-10-2015, 07:30 PM
YENKO DEUCE REGISTRY's Avatar
The power steering has a yellow decal, not paint.
The yellow on the sides of the block will likely be the engine application code of 'CTC', typically written on both sides, in yellow crayon, upside down.
I agree with you Ken, putting a block through the metal ax procedure after so many heat cycles normally doesn't 'relax' it very much but mine had a little bit of stress in it per the graph printout I received. In theory, I probably should have metal ax'd it after the machining was done....
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 03-10-2015, 07:44 PM
As I blew the pic up ...I could see the outside edges of where the decal was. [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
