Old 09-16-2015, 12:08 AM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Default 1959 "P" CASE WITH 4.88 GEARS. PART # 3788812 DATE
1959 "P" CASE WITH 4.88 GEARS. PART # 3788812 DATED K258
THIS HAS BEEN IN STORAGE FOR YEARS AND WAS A WORKING UNIT.
BUT SHOULD BE TAKEN APART FOR CLEANING ETC.
IT DOES ROTATE FINE, GEARS LOOK GOOD.
CARRIER IS NOT BEAT UP.
THE CARRIER IS CAST # C 30743. CANT FIND STAMPED RATIO OR ASSEMBLY STAMP, CAN ONLY MAKE OUT WHAT IS AN N,M OR Z ? LIGHT STAMP. THERE IS NO PITTING ON CENTER SECTION AND CAST NUMBERS AND P CODE LOOK GREAT. THIS WILL CLEAN UP NICE .
$750 SHIPPED
First I will take it.
Money order
Lower 48 only
Old 09-16-2015, 02:14 AM
Default Re: 1959 "P" CASE WITH 4.88 GEARS. PART # 3788812 DATE
What is the assy date and code for the original ratio? They are stamped on the RH front side of the unit.
It now has a 3 series carrier with a thick replacement ring gear.
thanks
Verne
Old 09-17-2015, 02:47 PM
Cleaned up case,only thing I can see is what is an N,M or Z nothing else and there is no pitting.Thanks Ed
Old 09-29-2015, 08:59 PM
still available
