Old 02-01-2016, 04:04 PM
ssl78 ssl78 is offline
Default 621 bellhousing
There is 2 different ones I see. The one has the GM under the part number on the side the other the gm is on top of the bellhousing. Which is correct for a 1969.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 02-01-2016, 09:11 PM
302moz 302moz is offline
Default Re: 621 bellhousing
I am trying to find out the same thing.Also the casting numbers are thin and some are thick.
Old 02-02-2016, 01:49 AM
Hawkeye's Avatar
Hawkeye Hawkeye is online now
I'm sure others will chime in, but my understanding is 69 and up had the GM on the side next to the part number. 68 and earlier has the GM where the cast line is down the center.
Please correct me if I have it all wrong.
Thanks,
Marty
Old 02-02-2016, 02:12 AM
There are 3 .....do not forget the 621 repops [img]<<GRAEMLIN_URL>>/no.gif[/img]
Old 02-02-2016, 03:03 AM
And Truck application differences too.
Old 02-02-2016, 07:47 AM
Rixls6 Rixls6 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">And Truck application differences too.
</div></div>
But the truck bellhousing isn't a 621.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 02-02-2016, 07:00 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">And Truck application differences too.
</div></div>
But the truck bellhousing isn't a 621. </div></div>
Sure it is.
GMC &amp; Chevrolet G-10 &amp; G-20 series trucks with 283cid. &amp; 307cid. used it,starting in 1967 up to I think 1978 models.
After that,the #464697 bellhousing superseded it.
Old 02-03-2016, 11:02 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Rixls6</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mr70</div><div class="ubbcode-body">And Truck application differences too.
</div></div>
Sure it is.
After that,the #464697 bellhousing superseded it. </div></div>
You're saying that the bellhousing pictured on the left, with the different bulged area at the bottom has the same casting number on it as the one on the right???
Rick
