Old 07-12-2016, 01:03 PM
bbbentley's Avatar
Default Re: 1969 Z/28 Original Radiator w/ 'UH' Tag
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: the427king</div><div class="ubbcode-body">I just shipped an Ls6 radiator out with an I date code on the tank ,so im thinking you are right on the NOV date. They certainly used I on the tank letter codes, for example I also thought the items not using the letter I was for electrical items only [starters.distributiors,alternators,etc etc ] Also that can be used as a 68 date or 69 date due to the strike. </div></div>
Not to beat a dead horse , but to set the record straight: K is an October radiator Sammy is correct and there was no strike causing the run extension of 69 Camaros. The extension was due to engineering problems with quarter stampings on the new 70 body.
FULL OWNER HISTORY
