Old 04-06-2017, 12:35 PM
rare4k rare4k is offline
Default Original Gm 1969 Corvette 427 Camaro Nova 396-350hp 7029215 Carburador
Here is a factory original GM Rochester Quadrajet 4 barrel carburetor. This carburetor was originally installed onto 1969 Chevrolet Corvette 427-390hp, Camaro SS 396, Chevelle SS 396, Nova SS 396, and Impala equipped with the 427-390hp hp engine and a manual transmission. This unit is a 100% real GM piece and guaranteed not to be a restamp. This carburetor has a part number of 7029215 EH This carburetor is 100% complete and everything moves freely with no issues. This just came off the shelf of an old restoration shop where it's been on the shelf for decades. Nothing is cracked or damaged. The bottom is nice with no cracks, damage, or corrosion and the mounting holes are in excellent shape. I would assume that this unit should be completely restored and gone through before use as it has been sitting on the garage shelf for many years. first 750.00 plus the ride
Old 04-06-2017, 01:19 PM
Rumbleguts396 Rumbleguts396 is offline
Hello, by chance do you know the date code of this carb? Month and year built. Thanks Rob
1969 Camaro SS 396 X66 Lemans Blue
1969 Corvette 427/390 Lemans Blue
Old 04-06-2017, 09:57 PM
no date on body that I can see
Old 04-06-2017, 10:04 PM
marxjunk marxjunk is offline
some early 69s had the date stamped on the base plate..rear drivers side/edge
EH is the pick code..so prob an assy line piece..it matches a build sheet..and the big R ink stamp is for assy line pick also...
if the orig base is on it..the date is there
Mark
Old 04-06-2017, 10:33 PM
here is what I found on the side
Old 04-06-2017, 10:49 PM
strange...ive seen it around the corner from that too
Mark
Old 04-06-2017, 11:06 PM
Thanks for your efforts. Anybody have a thought of what that date decodes too???
Old 04-07-2017, 12:26 AM
Ive looked into it a little the research I can make out is the its a early carb 35th week of 68 still don't no what the 2 or the G mean but all later carb after January are date stamped were the 7029215 is the base also has the small casting nO#s of 7037600 in the circle
Old 04-07-2017, 01:01 PM
Thank you again for your time and efforts. However my 1969 corvette is a late 1969 build so this won't work for me. Thanks Rob
Old 04-09-2017, 02:10 AM
sold pending payment
