Old 06-22-2017, 05:55 PM
Wish I could help. I ran into the same issue as you. There must be a few out there. However, if it is used, it will likely get dinged pretty good when removed. I suppose you could get one out using a 1 inch wooden dowel instead of steel or brass as the drift.
