Old 12-11-2017, 10:03 PM
Kramer77 Kramer77 is offline
Default Correct 1969 chevelle alternator
Hey everybody. Quick question. My chevelle is a V8 A/C car built on the fourth week of January 69. Staring to buy period correct parts for it when I can. For restoring purposes. My research tells me the alternator I want to get is the correct part number 61amp alternator. It has 9A20 stamped date code. That puts it at the 4th week of January. Same week my car was assembled. Wondering if this would be ok or if it needs to be a little earlier dated. Part number is 1100843. Which I’m sure is correct. It is rebuilt. They want 85$ all together. Any advice/info is appreciated.
Thanks
Attachments - The Supercar Registry C66B3A50-33BC-4D67-B70A-38F69EB3A4AF.png
Old 12-11-2017, 10:36 PM
Here is a photo of Clint’s alternator
Old 12-12-2017, 01:12 AM
wheelhop wheelhop is offline
I would say your best date would be 2 weeks to 8 weeks before assembly date. It also could depend on the build/assembly date of your motor.
So the date on the alternator is probably too late for your car, and I'm no expert on stamps but that looks like it could have been scratched off and re-stamped below.
Old 12-12-2017, 01:41 AM
That is no re-stamp....just screw driver markers from tightening the Alternator.
Old 12-12-2017, 02:14 AM
So what do you think Dan. Little to late for my car. Date code wise?
Old 12-12-2017, 03:23 AM
NOT LATE. I would use it....you will be fine.
Old 12-12-2017, 09:43 AM
I'd aim more for the build date of your engine,not the car.
I'd pass on it for that reason alone,if not for those hack marks too.
These alternators are plentiful,you can find better.
Old 12-12-2017, 12:12 PM
I'd use it but keep looking for an earlier version. The stars would have to align to make that date work with your tag.
Old 12-12-2017, 12:33 PM
Woj's Avatar
Woj Woj is offline
These alternators pop up pretty often. Another will come along before too long.
Phil Woj.
PS. My 69 Malibu shows a 63 Amp alternator on the build sheet. I have never even seen one yet. So I'm running a 61 Amp.
Old 12-12-2017, 01:11 PM
Just did a quick search,and because the one you showed has hack marks,here's a December 30th 1968 1100843 w/hack marks for $10 more,that might better fit your engines assembly date.
https://www.ebay.com/itm/1969-Chevel...BYxKD3&vxp=mtr
