appreciate all the feedback,However the Green Chevelle in the V gate thread is exactly that, a V Gate , Not a Ram Rod , which sure looks like it would take up alot more space....i've never had the v Gate, had a Ram Rod Years ago...so i don't know...any more thoughts on the space required for the Ram Rod is greatly appreciated!!!! Thank you all!!!
![]() Quote:
The reason these contraptions require so much metal carnage is that the rods are completely straight from the transmission levers on the side cover to the shifter mechanism. As a result, the shifter is mounted far left of the factory position. All I can tell is that from experience I had to cut a lot to make it clear everything. Last edited by njsteve; 04-26-2018 at 01:27 AM. |
The Following User Says Thank You to njsteve For This Useful Post: | ||
MECTransAm (04-26-2018) |
To confuse things further:-) my A body had a Street Super shifter with straight rods but no tunnel cutting.
Ryan
1969 Beaumont 350 Auto White Sold 1969 Beaumont 307 Auto Green Sold 1969 Chevelle SS 396-L35 Auto Blue Sold 1969 Oldsmobile Cutlass 'S' Sports Coupe W31 |
The Following User Says Thank You to Ryan1969Chevelle For This Useful Post: | ||
Hey Ryan 1969 Chevelle, would you happen to have any photos? they probably mount very similar...
![]() Quote:
The gate/body is mounted higher and closer to the driver so the rods are straight. This one is a push down for reverse model :-) Ryan
Al only cut the “hump” (the piece welded over the factory torch cut hole) and banged some areas for more room.
This is a 1969 Cutlass so the “hump” is low profile. Ryan
yes,i presently have that shifter ,but i'm using competition plus linkage and mounting bracket,,i like the push down reverse,...i'm thinking i might not have to cut the tunnel just cut for the shifter,but all these floorpans are different... and another dilemma..Finding a boot...without taking out a loan..lol.....Hey Big Gear Head...Do you have any photos????
