Old 05-04-2018, 03:38 AM
68 DANA's Avatar
68 DANA 68 DANA is offline
Yes, the one you purchased is from the 68/69 time frame. Although the 1510 part number was also used in 1970 there is a subtle difference in the hydroform process around the starter area.
The hardware, bolts, used on the scattershield were manufactured by Lake Erie and were identified by the manufacturing marks "LE" embossed on the head of the bolts. I have attached the actual Lakewood Hardware package "1581" for reference.
I hope this helps.
Hardware:
Bolt grade - 5
Head style - Hex cap
Lock washers yes/no - no
Washers - yes
Bolt color - zinc dichromate
Bolt head markings - LE
Scattershield:
Part No: 1510
Block Plate No: 1573
Bolt Pkg. No: 1581
The Following 3 Users Say Thank You to 68 DANA For This Useful Post:
Bernhard (05-04-2018), mockingbird812 (05-04-2018), PeteLeathersac (02-07-2021)
Old 05-04-2018, 03:47 AM
Bernhard Bernhard is offline
I hope this helps.
Hardware:
Bolt grade - 5
Washers - yes
Scattershield:
Part No: 1510
Bolt Pkg. No: 1581
Very Very cool thanks for posting.
69 442 post bench 3 pedal
Old 05-04-2018, 01:08 PM
I hope this helps.
Hardware:
Bolt grade - 5
Washers - yes
Scattershield:
Part No: 1510
Bolt Pkg. No: 1581
Dana - that is some good info and pix too! Thanks!
P.S. What is the application for the grade 8 "LE" bolt that you pictured?
