Old 08-03-2018, 12:54 PM
dlv4540 dlv4540 is offline
Default 1969 L88 CE Warranty Exchange Short Block
I have a 427 4 bolt standard bore short block standard bore with the original internals. The block was freshened up and has roughly 1000 miles on it and then put away. The block has the GM TRW high dome open chambered pistons, 7/16 dimple rods, 6223 steel crankshaft turned .010 under, correct timing cover and harmonic balancer but not correct oil pan. The motor turns over nicely and is very clean inside. The casting number is 3963512 dated L-3-9 and stamped CE058160 and assembly stamp on back bottom flat edge of T 02 0 which is February 1970 assembly. $6500 for the short block and can ship if you cannot pick up.
330-770-2517 for any questions and pictures can be provided as well.
Dennis Vugrinovich
Old 08-19-2018, 05:20 PM
Bump
Dennis Vugrinovich
