Old 05-14-2019, 01:28 AM
Enoch Enoch is offline
Banned
Accelerator throttle rod nylon bushing and rubber grommet. Excellent original pieces. the nylon bushing has its three cruising marks and C2 embossed on it. The rubber grommet is nos and has LU embossed on it. $45 shipped to the lower 48 ppff
Old 05-14-2019, 02:52 AM
302moz 302moz is offline
Default Z/28 crank bolt
I will take the z crank bolt and washer. Thanks
The Following User Says Thank You to 302moz For This Useful Post:
Enoch (05-14-2019)
  #43
Old 05-14-2019, 02:22 PM
Banned
Original assembly line installed ground bolt star washers. Many of the originals have much larger tabs than the current reproductions. Original ones like these are hard to find. 4 washers per set. $50 per set. Ppff 1 set left ************ SOLD *************
Old 05-14-2019, 02:59 PM
Banned
Big block oil line to head mounting clip and bolts. The clips has the original triangle stamping in the bolt his L head marking. Extremely hard to find clip. $80 PPFF
Old 05-14-2019, 04:54 PM
Banned
Original block drain plugs with S head marking on them. Extremely hard to find. $50.
Old 05-14-2019, 04:55 PM
Banned
Original 69 Camaro blue plastic tachometer stud cap. Excellent original piece. Hard to find Originals. $30.
Old 05-14-2019, 05:11 PM
Banned
Original top cowl plugs. For Camaro and Firebird. Very nice with manufacturer markings. $30 a pair. Three pair available.
Old 05-14-2019, 05:57 PM
Banned
Highlighted in the circle is where these go. And they're visible with the fenders installed.
Old 05-15-2019, 12:21 AM
Banned
Totally forgot I had these. Just came across them in a bin. Complete original set of 3 tachometer stud plastic covers. Pale blue translucent caps. The real deal. $75
Old 05-15-2019, 12:36 AM
Banned
Power brakes stop light switch extension bracket. Excellent original piece. Still has the manufacturers stamping on it. SOLD $35 SOLD
